Cisco Secure Services Client
Dec 7th, 2009
Do the Cisco SSC has the capabilities like when we have multiple AP's broadcasting the same SSID's; it allows us to choose which AP we can connect manually, regards of the signal strength (low/high). And, also does it have SSID profiles where we can set the IP address/gateway/dns to each of the profile. It is something like the IBM thinkvantage access connections.
Pls advise.
Rama
stsargen Mon, 12/21/2009 - 07:33
  • Cisco Employee,
The Wireless NIC driver determines which BSSD it will associate to basedon the NIC drivers algorithm.
The CSSC does not support per profile IP address/gateway/dns settings.
George Stefanick Mon, 12/21/2009 - 20:35
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
You can d/l a free trial of cssc.
Trending Topics - Security & Network
