2960 - SFP is loose in the Switche´s SFP bay
Dec 7th, 2009
Hi!
I´ve just installed 10x WS-C2960-48TC-L and 01x WS-C2960-24TC-L using GLC-SX-MM SFP modules, and in all (absolutely all of them) the SFP doesn´t fit really well... it´s kind of loose in the SFP bay, it looks like that either the SFP are manufactured too small or the SFP bay too big, because anytime we touch the fiber cable on those switches the SFP pop´s out, loosing the connection to the CORE.
Also tested in a 3750, and it fits better (not perfectly, but better), at least it doesn´t pop out when touching the fiber cable...
My question is, anyone faced this issue already?! Any official word from Cisco about this issue?!
Thanks!
Reza Sharifi Mon, 12/07/2009 - 10:49
That should not be the case with new products.  I have had the same issues with 3750s from Demo Depot, but that is because the get abused by the customers.  The SFP or X2 modules in new products should fit nicely
I would talk to the sales person to get replacement.
Reza
bascheew Mon, 10/18/2010 - 09:53
We have a customer with the same problem.  We just installed a few 2960 switches (both WS-C2960G-48TC-L and WS-C2960G-24TC-L) and every single SFP module is very loose and will go dead with the slightest touch.  The TAC sent us new modules but they do the same thing.  We are going to call them back and see what they'd like us to do.  In the meantime we are using media converters as they could not be relied upon for production.
johnmilan Mon, 11/22/2010 - 15:16
I had the same problem and thought I was doomed as I have to install several 2960G's with GLC-LH-SM used for uplinks.
Insert the SFP, do not remove the rubber boot dustcover. Then do a karate chop using the heel of your hand to hit the dustcover boot and the SFP will lock into place.
