gridnutter Mon, 12/07/2009 - 05:46
I tried creating a new 9.@ route pattern and set the Caller ID to restrict. I then created a new CSS and Partition for the 2 phones.
For some reason it seems that this route pattern is being used globally, and is restricting Caller ID for all phones.
Jaime Valencia Mon, 12/07/2009 - 07:18
  • Cisco Employee,
  • Hall of Fame,
    2011
The process is very simple, you mentioned you created a new CSS and PT for phones?? because that doesn't make sense if you want to block the CLID from those 2 phones in the RP for PSTN outgoing calls.
You need to create a new CSS and PT FOR THE ROUTE PATTERN.
Then make sure only those 2 phones have that partition in their CSS.
In the RP use the calling party transformations to block sending their DN.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
