Martyn Sharpe Tue, 12/08/2009 - 00:42
Nope it's not the same username/password as the CUC admin web page, tried that and it doesn't work hence I asked the question.
asandborgh Tue, 12/08/2009 - 11:36
  • Silver, 250 points or more
Martyn,
You should be able to log onto CCM, create another application user in the CCM super user group and log on with that user ID.
HTH,
Art
asandborgh Tue, 12/08/2009 - 12:58
oops - sorry  - missed that, but you can do basically the same thing on CUC.  Add a new user and assign them the role of system administrator, set the password and you should be able to use that user for RTMT.
Cheers!
Art
WSonnylal Wed, 12/16/2009 - 22:17
I've used RTMT with several installs of CUC 7.x and it is the same userid and password that you would use for the the web administration page.  Strange that it is not working for you.
