Unity Express 2.2 to 7.1 Upgrdae
Dec 7th, 2009
Experts,
Need your quick help.
Can I re-use existing CUE2.2 mailbox licences on CUE7.1?
My customer has got NM-CUE module installed with CUE2.2 and they want it to be upgraded to 7.1 release. I am aware that EoS NM-CUE doesn't support CUE7.1 and hence they need new hardware for the job which I have quoted. But, I am stuck with "licensing" wondering if I can re-use the existing mailbox licences by any chance for e.g. by loading it to Cisco licensing portal and get them converted to 7.1
OR do I need to purchase new mailbox licences as well?
Thanks.
Pablo Daniel Go... Fri, 12/11/2009 - 13:36
Hi JB S,
Licensing model for CUE 7.1 has change and now they use CSL licenses. However if you want to migrate your licenses please check the following document:
Migrating to CSL Licenses
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/Licensing/Using_CSL.html#wp1106878
On the previous link there is a note that you might find useful:
"If you are upgrading to the same of licensed features as before, the CSL licenses are free."
HTH,
pablogon
Pablo Daniel Go... Fri, 12/11/2009 - 14:18
You might also want to check rehosting licenses section on the same link since you are changing the hardware.
HTH,
pablogon
