Time schedule
Dec 7th, 2009
Hello, my customer  after every holiday he wants to open earlier and close later, I was trying to accomplish this copying the same steps as the holiday schedule Just using a different XML doc. when i test the script i get exception -1 error. does anybody know what this is. also does anybody have a different way to accomplish this or a way so customer can change the business hours without messing with the script.
Thanks.
James Hawkins Mon, 12/07/2009 - 15:29
I normally use a variable which can have three values:
  • Open
  • Closed
  • Calendar
This variable is checked by the script when a call arrives and routed to the appropriate branch. Open and Closed should be self-explanatory. Calendar uses the holiday.xml script to check for holidays then uses day of week and time of day steps to route calls.
I write an admin script which allows the callcenter manager to change the variable above. When they want to close early they just set it to closed using the IVR, if they want to open late the set it to open. Most of the time it uses the calendar setting.
Hope this helps.
