Problem to unistall Cisco Supervisor Destktop
Answered Question
Dec 7th, 2009
Hi Guys,
My Customer have a IPCC 5.0.2 Rebuild 45. After install this release, the CSD had change, because, CSD was with another version. Our Customer uninstall the previous version and did download of plugin the last version, but, It is presenting error. Are there any procedure to unistall the previous version?
Thank You,
Wilson Santana
Correct Answer by Rajiv Lal about 6 years 10 months ago
Hi ,
Sometimes uninstalling the CAD from add/remove programs does  not remove some of the components and we need to manually clear some of the registery keys.
Here is a link for the document that will guide to maually remove CAD.
Please rate all docs.
Overall Rating: 5 (1 ratings)
wilsonsant Tue, 12/08/2009 - 03:12
Hi Hajiv,
This documment refer the version 4.0.x. Is it used too to version 5.0.x?
Thank You,
Wilson Santana
