12-07-2009 01:19 PM - edited 07-03-2021 06:20 PM
Hi Experts!
Can I have wpa and wpa2 on the same SSID available for both kind of users?
Miguel
Solved! Go to Solution.
12-07-2009 01:31 PM
Miguel,
While you can enable both it is preferred to select only 1 of them, but if you choose to have both enabled I reccomend that you configure them as follows:
WPA - TKIP Only
WPA2 - AES Only
Kayle
12-07-2009 10:21 PM
As mentioned already running 2 security postures on the same SSID can cause issues with connectivity. I tested this over a year ago and i discovered older clients (intel 2200s) and others struggled at times during roaming and associations.
12-07-2009 01:31 PM
Miguel,
WPA - TKIP Only
WPA2 - AES Only
Kayle
12-07-2009 10:21 PM
12-18-2009 02:57 PM
Thanks to both!
