FXO Not disconnecting
Dec 7th, 2009
Is there any way to have my FXO port disconnect after a certain time limit?  I have calls staying up for over 1 hour and I want them to die after 30 minutes.  Can I do this with an FXO port?
ragulan_dms Mon, 12/07/2009 - 22:09
  It is a common problem with loop start signalling. Can you try to use ground start signaling rather than loop start signalling and see whether it help ?
asandborgh Tue, 12/08/2009 - 06:00
I'm not sure if this is what you are asking for - this applies to a situation where someone hangs up and
the FXO port does not disconnect - try the following commands -
voice-port x/x/x
supervisory disconnect dualtone mid-call
timeouts call-disconnect 1
timeouts wait-release 1
timing guard-out 500
no shut
infosateng Tue, 12/08/2009 - 07:56
What I am trying to acomplish in this one is I want any call to drop after 30 minutes.  Basically I want a timer, that says after 30 minutes where someone is still chatting away or not, drop the call, close the FXO port.
asandborgh Tue, 12/08/2009 - 08:06
This Service Parameter will do what you want - but it is global....
Maximum Call Duration Timer:  This parameter specifies the minutes that a call can remain active before Cisco CallManager clears it. A value of zero disables the timer.
This is a required field.
Default:  720
Minimum:  0
Maximum:  35791
Unit: min
infosateng Tue, 12/08/2009 - 08:32
Thanks for the comments, but what is the actual command?
Also I am not using a Call Manager here, so not sure if it will apply.
asandborgh Tue, 12/08/2009 - 08:35
Sorry, that is a CCM service parameter.  I know of no IOS command that will disconnect
an FXO port after a certain call duration.
Anyone else?
Good Luck!
