UCCX 7.x question
Answered Question
Dec 7th, 2009
I have a problem with one of my scripts I just wrote. Everytime I power cycle the computer the new promts and directories are not retained.
Someone said he saw this before in the old IPCC version and said the files needed to be loaded up and not just coipied.
Is that correct? How do I upload a prompt and directory if required?
Randall
Correct Answer by Jonathan Schulenberg about 7 years 3 months ago
This is because you copied the files to the hard drive directly. You *must* upload all prompts, documents, grammer, and scripts through the /appadmin interface into the appropriate repository. The contents of the repositories are stored in SQL and copied down to disk periodically for run time use. Anything present on the disk is overwritten or erased.
Overall Rating: 5 (1 ratings)
Correct Answer
Jonathan Schulenberg Wed, 12/09/2009 - 05:33
  • Cisco Designated VIP,
    2017 IP Telephony
rcrumm_2 Mon, 12/14/2009 - 14:33
Thanks Johnathan,
I found that out already. Sorry for the late response.
5 points for you.
Randall
