Re: Cisco Call Manager 7.0 : routng of call to Main number
Answered Question
Dec 7th, 2009
I am having a problem with a routing calls from the PSTN to main number configured on the system.
I have configured a Cisco 2821 gateway with t1 CAS circuit for PSTN connectivity and I am using MGCP as the protocol for communication bet gateway and cisco Call Manager.
I am able to make calls and receive calls via DID however when I try to receive a call from the Telco the number hits the gateway but is not being routed to the configured extension.
Attached is a copy of the log from the bebug, can you assist?
NB
When I dial the DN from an internal extension, the call is routed correclty. The Telco is sending the last 4 digits of the main number
C2821-Gate2#debug voip vtsp all
voip vtsp all debugging is on
C2821-Gate2#
*Dec  7 23:55:42.030: //-1/xxxxxxxxxxxx/VTSP:(0/0/0:1):-1:-1:-1/vtsp_allocate_cd
b:
   CDB=0x489C37C8
*Dec  7 23:55:42.030: //-1/xxxxxxxxxxxx/VTSP:(0/0/0:1):-1:-1:-1/vtsp_do_call_set
up_ind:
   Event=E_TSP_SETUP_IND
   Progress Indication=3, CarrierIDCode=, Info Trans Capability=144, Source Carr
ier ID=, tg_label_flag=0
*Dec  7 23:55:42.030: //-1/DC99FBA0814B/VTSP:(0/0/0:1):-1:-1:-1/vtsp_do_normal_c
all_setup_ind:
*Dec  7 23:55:42.030: //-1/DC99FBA0814B/VTSP:(0/0/0:1):-1:-1:-1/vtsp_timer:
   Timer Start Time=124008541, Timer Value=180000(ms)
all_setup_ind:
   XCC State Machine (XCCSM) Added
*Dec  7 23:55:42.030: //-1/DC99FBA0814B/VTSP:(0/0/0:1):-1:-1:-1/vtsp_insert_cdb:
*Dec  7 23:55:42.030: //-1/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_dsm_opened_cb
*Dec  7 23:55:42.030: //-1/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_process_event
   [state:S_SETUP_IND_PEND, event:E_VTSP_DSM_OPEN_SUCCESS]
*Dec  7 23:55:42.030: //-1/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/act_setup_ind_pend
_success:
*Dec  7 23:55:42.030: //-1/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_realloc_cdb:
   CDB=0x489C37C8
*Dec  7 23:55:42.030: //-1/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_indicate_call
*Dec  7 23:55:42.034: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_insert_cdb:
*Dec  7 23:55:42.034: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_timer:
*Dec  7 23:55:42.034: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_process_event
   [state:S_SETUP_INDICATED, event:E_CC_SETUP_ACK]
*Dec  7 23:55:42.034: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/act_setup_ind_ack:
   Fax Relay=FALSE, Dial Tone=FALSE, Digit Collect=TRUE, Overlap=FALSE, DID=TRUE
*Dec  7 23:55:42.038: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=124008542
*Dec  7 23:55:42.038: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/act_setup_ind_ack:
   Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms), Playout Max=1000(
ms), Fax Nom=300(ms)
*Dec  7 23:55:42.486: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_dsm_digit_beg
in_cb:
in_cb:
   Begin Digit=2
in_cb:
   Digit Reporting=FALSE, Digit Consume=FALSE, Digit Relay=FALSE
*Dec  7 23:55:42.550: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_dsm_digit_end
_cb:
*Dec  7 23:55:42.550: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=124008593
_cb:
   End Digit=2
_cb:
*Dec  7 23:55:42.626: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_dsm_digit_beg
in_cb:
*Dec  7 23:55:42.630: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_dsm_digit_beg
in_cb:
   Begin Digit=4
in_cb:
*Dec  7 23:55:42.686: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_dsm_digit_end
_cb:
*Dec  7 23:55:42.686: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=124008606
_cb:
   End Digit=4
_cb:
*Dec  7 23:55:42.770: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_dsm_digit_beg
in_cb:
in_cb:
   Begin Digit=2
in_cb:
*Dec  7 23:55:42.826: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_dsm_digit_end
_cb:
*Dec  7 23:55:42.826: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=124008620
_cb:
   End Digit=2
*Dec  7 23:55:42.830: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_dsm_digit_end
_cb:
*Dec  7 23:55:42.910: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_dsm_digit_beg
in_cb:
in_cb:
   Begin Digit=4
in_cb:
*Dec  7 23:55:42.970: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_dsm_digit_end
_cb:
*Dec  7 23:55:42.970: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=124008635
_cb:
   End Digit=4
_cb:
*Dec  7 23:56:07.874: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_process_event
   [state:S_DIGIT_COLLECT, event:E_TSP_DISCONNECT_IND]
*Dec  7 23:56:07.874: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/act_generate_disc:
   Cause Value=16
*Dec  7 23:56:07.874: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=124011125
*Dec  7 23:56:07.874: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_ring_noan_tim
er_stop:
*Dec  7 23:56:07.874: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_set_release_s
ource:
   Release Direction=PSTN, Release Source=Calling Party-PSTN
*Dec  7 23:56:07.874: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_cc_call_disco
nnected:
nnected:
   Cause Value=16
*Dec  7 23:56:07.874: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_timer:
   Timer Start Time=124011125, Timer Value=15000(ms)
   Return Code=0
   [state:S_WAIT_HOST_DISC, event:E_CC_DISCONNECT]
*Dec  7 23:56:07.874: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/act_host_disc_clea
nup:
   dsm_indicate_error=0, short_cleardown_timeout=1, Mode=0
*Dec  7 23:56:07.874: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_dsm_save_fax_
config:
config:
   Call Entry=NULL, Call Id=-1
nup:
   Exit State=16
*Dec  7 23:56:07.874: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_dsm_get_level
s_done_cb:
   [state:S_WAIT_STATS, event:E_VTSP_DSM_STATS_COMPLETE]
*Dec  7 23:56:07.874: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/act_dsm_dsp_stats_
complete:
   Timer Start Time=124011125, Timer Value=60000(ms)
*Dec  7 23:56:08.274: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_process_event
   [state:S_WAIT_RELEASE, event:E_TSP_DISCONNECT_CONF]
*Dec  7 23:56:08.274: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/act_wrelease_relea
se:
*Dec  7 23:56:08.274: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_play_busy_tim
er_stop:
   Timer Stop Time=124011165
*Dec  7 23:56:08.274: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_timer_stop:
*Dec  7 23:56:08.274: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_do_call_histo
ry:
ry:
   Coder Rate=-1
*Dec  7 23:56:08.274: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:1:1/vtsp_is_valid_dsm_
handle:
   DMGR=0x489773D4, VTSP CDB=0x489C37C8
*Dec  7 23:56:08.278: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:-1:-1/vtsp_dsm_closed_
cb:
*Dec  7 23:56:08.278: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:-1:-1/vtsp_process_eve
nt:
   [state:S_CLOSE_DSPRM, event:E_VTSP_DSM_CLOSE_COMPLETE]
*Dec  7 23:56:08.278: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:-1:-1/act_terminate:
*Dec  7 23:56:08.278: //93/DC99FBA0814B/VTSP:(0/0/0:1):-1:-1:-1/vtsp_timer_stop:
   Timer Stop Time=124011166
*Dec  7 23:56:08.278: //-1/DC99FBA0814B/VTSP:(0/0/0:1):-1:-1:-1/vtsp_free_cdb:
   CDB=0x489C37C8
I am not sure what is the cause of this can you assist?
Correct Answer by mightyking about 7 years 3 months ago
Change the service parameter "DisableAlertingPI" to True.
MK
Overall Rating: 5 (1 ratings)
ragulan_dms Mon, 12/07/2009 - 22:05
I am just confused by " I am able to make calls and receive calls via DID however when I try to receive a call from the Telco
the number hits the gateway but is not being routed to the configured extension."
Can you make the call to PSTN from internal extension ? And could you please tell me bit clearly what is the problem with incoming calls ?
Thanks.
m-laing Tue, 12/08/2009 - 06:33
This is the problem
I have Call Manager configured to access 4 digits from the ISP. I am using a cisco 2821 with One T1 CAS circuit.
The ISP has provided DID service for this circuit and  is forwarding the last 4 digit of the DID numbers. The challenge I am having relates to the main pilot number for the company. The ISP is forwarding 2424 as four digit of the main number and when I do i voice voice call summary I am seeing that the call actually is sezing channel 13 of the T1 circuit, however the call is not being routed to the destination.
On call Manager I have configured the T1 gateway to accept 4 digits and there is a translation pattern configured to route 4 digit that 2424 to the pilot number of the attendant console. I am able to dial 2424 from an internal extension and the call is terminated on the pilot number for the attendant console. However when I dial the main number from the PSTN the call hits the gateway however it is not routed.
If a configure a phone with DN 2424 the same thing happens.
m-laing Tue, 12/08/2009 - 06:34
This is the problem
asandborgh Tue, 12/08/2009 - 06:49
  • Silver, 250 points or more
Ok, just to confirm - when you call in on this circuit to ANY IP phone, does the call route and the phone ring? (Just simplifying it down right now)
Again, does the CSS assigned to the gateway have visibility to the phones/translation pattern?
m-laing Tue, 12/08/2009 - 07:05
When I call into the DID numbers the extension rings on the phone. However this is not the case with the main number
Main Number: 9272424
I have setup a phone with DN 2424
DID Range 7025150 - 5399 , ISP forward 4 digits and no problem
The Gateway is configured in a CSS-GWY and the partition for the phones and other devices are in this CSS assigned to the gateway.
asandborgh Tue, 12/08/2009 - 07:49
Considering the debug and the fact that your other phones work when called inbound it appears that your gateway and ISP are fine.
Please try the following:
Make sure there is no other device or line that has 2424 assigned (route plan report)
Take the 2424 line on the phone and put it in the partition so it is completely visible
Try the call again
Art
m-laing Tue, 12/08/2009 - 14:31
I removed DN 2424 from the partition and it still does not work, is there any
thing else I can try
asandborgh Tue, 12/08/2009 - 06:08
Is the Calling Search Space on the gateway set so it can access the line?
What is the full number and the internal extension that is being accessed here?
Art
ragulan_dms Wed, 12/09/2009 - 01:39
1. From the debug PSTN send the digits.
2. When you dial 2424 from internal extension, you can reach AA. - translation patten CCS can reach the pilot number.
3. Phone with extension 2424 does not receive call. - Gateway did not send the call to CCM. ( I believe the CCS and partition are configured properly and temp. remove the translation)
   Since Gateway did not send the 2424 it the CCM, you may share the gateway config and the pilot number. And whether is it a MGCP or H323 gateway ? Also provide debug voip ccapi inout. The more information you provide the better we can understand.
Thanks.
Correct Answer
mightyking Wed, 12/09/2009 - 07:22
MK
