CSM 3.3.1 : Big database
Answered Question
Dec 7th, 2009
Hi there,
is there any way to shrink a CSM 3.3.1 Database ?
I have a 3 gb DB and it causes problem for replication
thanks for your help
Correct Answer by Panos Kampanakis about 7 years 7 months ago
You can do is go to Tools > CSM Admin. Under Archived you can go and delete the archives of all your devices and only leave the last 10 for example.
That should significantly decrease the disk used.
I hope it helps.
PK
Overall Rating: 5 (1 ratings)
Correct Answer
Panos Kampanakis Tue, 12/08/2009 - 11:35
  • Cisco Employee,
I hope it helps.
PK
martin.payette@... Thu, 12/10/2009 - 11:27
Excellent!
I tried this on our DR CSM: worked liked a charm.
When keeping only 3 config versions per device, I went from 3 Go to 240 Mo
Thanks again!
