how to convert the wav to G.729
QFX527518
when use cisco ipCC CRA,when we upload new Prompt, the error is The prompt file has an incompatible codec with that installed in the system。
why?how can we change the wav file to support G.729.???????????
asandborgh
Level 4
Level 4
A bit confused about your post.  You select the codec for the IPCCX system at installation, and you can see which is selected by going to System>System Parameters from the main menu (see below)
Your prompt will need to match that format.  If your IPCCX is running G711 you can easily record your prompt using sound recorder.  If it is running G729 you will need to find a G729 recorder, or if you are lucky you can use Unity (if you are running G729 as your format on it).
HTH,
Art
asandborgh
Level 4
Level 4
HTH,
Art
thx。because installing select the code is G729,so must use G.729 code wav.but now can't find G.729 recorder.anyone have tools for change the code or convert.thx.
use Call manager cisco MOH Audio Translator, can change the PCM to G.729.
thx.
