08-10-2009 08:00 AM
Hello Cisco Community,
Have a question related to the router mentioned in the subject, and we are wondering on how to enable Keepalive and DPD
We are using the following firmware V1.00.09-ETSI, and we can not see this options under the VPN Tunnel Configuration.
Thank you!
Victor.-
Solved! Go to Solution.
08-10-2009 11:02 AM
WRVS4400N does not support Dead Peer Detection. Whenever the router finds the tunnel dead when there is an outgoing packet from the local to the remote subnets, it will try to reconnect the tunnel.
08-10-2009 11:02 AM
