How to enable content filter for DistributionGroup
Answered Question
Correct Answer by jsteer about 7 years 5 months ago
Mads - i'd check that the message is :
a. is the address correct as it's comes through from the internet?
b. is the content filter active
c. what do you see in the mail_log when the message passes thru?
I'd suggest you use the trace option in the GUI to mimic a message to this address and see wha the output is.
The rcpt-to-group rule is using ldap to match up an address. Is your ldap connection setup?
Perhaps its worth changing the filter to be:
Blacklist_distributiongroup: if (rcpt-to == [email protected]) {drop(); }
Good luck
jason
Overall Rating: 5 (1 ratings)
Correct Answer
jsteer Wed, 12/09/2009 - 09:38
Good luck
jason
