RME 4.3.1 - Inventory Collection : Sybase -638 Error
Dec 8th, 2009
Hello all,
with certain Routers Cisco803ISDN we are actually unable to get inventory data (other devices are collected correctly)
In IC_Server.log the following Sybase error is shown
IC_Server.log
[ Tue Dec 08  10:15:12 CET 2009 ],ERROR,[Thread-26],com.cisco.nm.rmeng.util.logger.RMELogger,770,com.cisco.nm.rmeng.inventory.ics.invchange.AddInvChange,effect,33,Unexpected
error :com.sybase.jdbc2.jdbc.SybSQLException: SQL Anywhere Error -638: Right truncation of string data
It seems that the description of the IOS-SW is source of the problem, doing a octal dump (od) I discovered that
at the of each line of system-description a additional blank is added (<blank>\r\n).
Devices where inventory is collected correctly do have end-of-line characters (\r\n) without the blank.
Is that a problem to IC_Server or a bug in IOS-Image?
Thanks for any feedback
Lothar
Please find attached complete error-message in IC_Server.log
[ Tue Dec 08  10:15:12 CET 2009 ],DEBUG,[Thread-26],com.cisco.nm.rmeng.util.logger.RMELogger,734,com.cisco.n
m.rmeng.inventory.ics.dbrep.DBRecord,insert,60,Insert Query :
INSERT INTO SoftwareElement(SoftwareElementID, NetworkElementID, ProductName, Manufacturer, Version, BuildTime, PartOrImageID, SerialNumber, LogicalId, EnableToRun, FeatureSet,
SoftwareMedia, NumberRunning, Description, ElementName, ModuleId) VALUES(?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) :  SoftwareElementID = 1 NetworkElementID = 1455  Pro ductName = null  Manufacturer = null  Version = SOFTWARE (fc1)
TAC:Home:SW:IOS:Specials for info
Copyright (c) 1986-1998 by cisco Systems  BuildTime = null  PartOrImageID = null  SerialNumber = null  LogicalId = 2  EnableToRun = null  FeatureSet = null  SoftwareMedia = n ull  NumberRunning = null  Description = Cisco Internetwork Operating System Software
IOS (tm) C800 Software (C800-G3N-MW), Version 12.0(1)XB1,  RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-1998 by cisco Systems, Inc.
Compiled Wed 30-Dec-98 11:11 by ayeh
  ElementName = null  ModuleId = null
        at com.sybase.jdbc2.tds.Tds.processEed(Tds.java:2884)
        at com.sybase.jdbc2.tds.Tds.nextResult(Tds.java:2206)
        at
com.sybase.jdbc2.jdbc.ResultGetter.nextResult(ResultGetter.java:69)
        at
com.sybase.jdbc2.jdbc.SybStatement.nextResult(SybStatement.java:220)
        at
com.sybase.jdbc2.jdbc.SybStatement.nextResult(SybStatement.java:203)
        at
com.sybase.jdbc2.jdbc.SybStatement.executeLoop(SybStatement.java:1766)
        at
com.sybase.jdbc2.jdbc.SybStatement.execute(SybStatement.java:1758)
        at com.sybase.jdbc2.jdbc.SybPreparedStatement.execute(SybPreparedStatement.java
:630)
        at
com.cisco.nm.rmeng.inventory.ics.dbrep.DBRecord.insert(DBRecord.java:61)
        at com.cisco.nm.rmeng.inventory.ics.util.ICSDatabaseConnection.insert(ICSDataba
seConnection.java:92)
        at com.cisco.nm.rmeng.inventory.ics.invchange.AddInvChange.effect(AddInvChange.
java:29)
        at com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor.processInvData(InvD
ataProcessor.java:404)
        at com.cisco.nm.rmeng.inventory.ics.core.CollectionController.run(CollectionCon
troller.java:462)
        at java.lang.Thread.run(Thread.java:595)
[ Tue Dec 08  10:15:12 CET 2009 ],ERROR,[Thread-26],com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor
,458,SQL Anywhere Error -638: Right truncation of string data
        at
        at
        at
        at
        at
:630)
        at
java:29)
troller.java:462)
[ Tue Dec 08  10:15:12 CET 2009 ],ERROR,[Thread-26],com.cisco.nm.rmeng.inventory.ics.core.CollectionControll
er,468, Exception occured in process method while processing: 10.1 63.63.144 SQL Anywhere Error -638: Right truncation of string data ICSException :: SQL Anywhere Error -638: Right truncation of string data
ataProcessor.java:473)
troller.java:462)
m.rmeng.common.notification.Notification,refreshPrefsCache,233,Obt
ained Notification Configuration values from CCR
m.rmeng.common.notification.Notification,getCCRValue,88,is_notific
ation_enabled  CfgDisabled:InvDisabled
[ Tue Dec 08  10:15:12 CET 2009 ],INFO ,[Thread-26],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,596,
No Trap
[ Tue Dec 08  10:15:12 CET 2009 ],INFO ,[Thread-26],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,602,
CALLING SELF TEST
Overall Rating: 4 (1 ratings)
Joe Clarke Tue, 12/08/2009 - 10:32
This is an IOS bug.  The image description is longer than the allowed 255 characters.  You can workaround this by going to RME > Admin > Inventory > Inventory Change Filter, and check the boxes Image:Description and Image:System Description.  Inventory should work then.
lo.mueller Thu, 12/10/2009 - 00:17
Hi Joe,
thanks for your feedback.
I activated InvFilter, but (sorry) still collection is not possible - same error message in IC_Server.log.
What further can be done?
Thanks a lot
Lothar
IC_Server.log
[ Thu Dec 10  09:07:24 CET 2009 ],DEBUG,[Thread-39],com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor
,389,
Inventory Update
,390,================
[ Thu Dec 10  09:07:24 CET 2009 ],DEBUG,[Thread-39],com.cisco.nm.rmeng.util.logger.RMELogger,734,com.cisco.n
m.rmeng.inventory.ics.dbrep.DBRecord,update,82,Update Query : UPDATE ElementInventoryInfo SET UptimeTimestamp = '2009-04-15 04:10:43.057' WHERE NetworkElementID = '19' [ Thu Dec 10  09:07:24 CET 2009 ],DEBUG,[Thread-39],com.cisco.nm.rmeng.util.logger.RMELogger,734,com.cisco.n
m.rmeng.inventory.ics.dbrep.DBRecord,update,82,Update Query : UPDATE PhysicalElement SET NumberOfCommunicationConnectors = '2' WHERE PhysicalElementID = '1' AND NetworkElementID = '19' [ Thu Dec 10  09:07:24 CET 2009 ],DEBUG,[Thread-39],com.cisco.nm.rmeng.util.logger.RMELogger,734,com.cisco.n
m.rmeng.inventory.ics.dbrep.DBRecord,update,82,Update Query : UPDATE PhysicalElement SET NumberOfCommunicationConnectors = '2' WHERE PhysicalElementID = '2' AND NetworkElementID = '19' [ Thu Dec 10  09:07:24 CET 2009 ],DEBUG,[Thread-39],com.cisco.nm.rmeng.util.logger.RMELogger,734,com.cisco.n
m.rmeng.inventory.ics.dbrep.DBRecord,update,82,Update Query : UPDATE MemoryPool SET Allocated = '2537420' , Free = '6453120' WHERE PoolID = '2' AND NetworkElementID = '19' [ Thu Dec 10  09:07:24 CET 2009 ],DEBUG,[Thread-39],com.cisco.nm.rmeng.util.logger.RMELogger,734,com.cisco.n
m.rmeng.inventory.ics.dbrep.DBRecord,update,82,Update Query : UPDATE SoftwareElement SET Version = 'SOFTWARE (fc1)
Copyright (c) 1986-1998 by cisco Systems' WHERE SoftwareElementID = '1' AND NetworkElementID = '19' [ Thu Dec 10  09:07:24 CET 2009 ],ERROR,[Thread-39],com.cisco.nm.rmeng.util.logger.RMELogger,770,com.cisco.n
m.rmeng.inventory.ics.invchange.UpdateInvChange,effect,43,Unexpected error
        at com.sybase.jdbc2.jdbc.ResultGetter.nextResult(ResultGetter.java:69)
        at com.sybase.jdbc2.jdbc.SybStatement.nextResult(SybStatement.java:220)
        at com.sybase.jdbc2.jdbc.SybStatement.nextResult(SybStatement.java:203)
        at com.sybase.jdbc2.jdbc.SybStatement.updateLoop(SybStatement.java:1702)
        at com.sybase.jdbc2.jdbc.SybStatement.executeUpdate(SybStatement.java:1685)
        at com.sybase.jdbc2.jdbc.SybStatement.executeUpdate(SybStatement.java:431)
        at com.cisco.nm.rmeng.inventory.ics.dbrep.DBRecord.update(DBRecord.java:83)
        at com.cisco.nm.rmeng.inventory.ics.util.ICSDatabaseConnection.update(ICSDatabaseConnection.java:140)
        at com.cisco.nm.rmeng.inventory.ics.invchange.UpdateInvChange.effect(UpdateInvChange.java:37)
        at com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor.processInvData(InvDataProcessor.java:404)
        at com.cisco.nm.rmeng.inventory.ics.core.CollectionController.run(CollectionController.java:462)
[ Thu Dec 10  09:07:24 CET 2009 ],ERROR,[Thread-39],com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor
[ Thu Dec 10  09:07:24 CET 2009 ],ERROR,[Thread-39],com.cisco.nm.rmeng.inventory.ics.core.CollectionControll
er,468, Exception occured in process method while processing: R302 SQL Anywhere Error -638: Right truncation of string data ICSException :: SQL Anywhere Error -638: Right truncation of string data
        at com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor.processInvData(InvDataProcessor.java:473)
Joe Clarke Thu, 12/10/2009 - 07:51
This is something different, and I suspect still a device bug.  Given that this is a limited life train, I think it would be beneficial to upgrade this device to a mainline or T train to see if the problem persists.  If it does, then a bug could be raised.
