VRF-Lite and tagging
Dec 8th, 2009
We are using VRF-Lite and BGP on a customer router, and trunking to a customer switch internally. We are seeing a very large routing table (in excess of 200k routes).
We are seeing an error message:
TAGCON-3-LCLTAG_ALLOC : Cannot allocate local tag
Which I understand is usually only seen when running MPLS, which we are not.
Even stranger, it is resolved by the 'tag-switching tag-range downstream 16 100000 0' (now deprecated).
I notice that the output of 'show tag-switching forwarding-table ..' shows each route being allocated an internal tag.
Can anyone explain why these tags are being assigned?
Thanks.
Giuseppe Larosa Tue, 12/08/2009 - 06:33
  • Hall of Fame,
    Founding Member
Hello Ken,
you haven't provided much details.
What model is the customer router and what IOS is running on it?
You may have configured the device as you say for VRF lite but it may be trying to assign an MPLS label or older name tag to each prefix in the routing table
another way to solve this would be to use an ACL to decide for what prefixes a tag has to be allocated
something  like
no tag-switching advertise-tags
tag-switching advertise-tags for ACLname
the device thinks it is a full PE node.
Hope to help
Giuseppe
ken.vance Tue, 12/08/2009 - 06:58
Hi Guislar,
for further info:
Cisco 3845
IOS: c3845-spservicesk9-mz_124-19b
ip cef
ip vrf DIA
rd 29000:1
interface GigabitEthernet0/0.10
description customer Lan Office
encapsulation dot1Q 10
ip address XXXX  XXXX
no cdp enable
interface GigabitEthernet0/0.11
description customer LAN internet
encapsulation dot1Q 11
ip vrf forwarding DIA
ip address XXXX  XXXXX
no cdp enable
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.38
encapsulation dot1Q 38
ip address XXXXXXX mask XXXXXXX
no cdp enable
interface GigabitEthernet0/1.40
encapsulation dot1Q 40
ip address XXXXXX  mask XXXXXXXXX
no cdp enable
router bgp XXXXX
no synchronization
bgp log-neighbor-changes
network XXXXXXX mask XXXXXX
neighbor XXXXXX remote-as XXXX
neighborXXXXXX  version 4
default-information originate
no auto-summary
address-family ipv4 vrf DIA
  neighbor XXXX remote-as XXXX
  neighbor XXXX version 4
  neighbor XXXX activate
  no synchronization
exit-address-family
The 'safe' parts of the config.
Okay, its not a real fault, more interested in why the internal tags are being assigned in the first place.
Does anyone have any ideas?
Giuseppe Larosa Tue, 12/08/2009 - 10:14
  • Hall of Fame,
    Founding Member
Hello Ken,
the explanation can be as simple as a default settings.
it  is enough  that mpls ip/tag-switching ip is enabled by default in global mode to lead the device to start allocating labels.
IOS: c3845-spservicesk9-mz_124-19bip cef
if so you just need
conf t
no mpls ip
or
no tag-switching  ip
to free resources.
see
Defaults
Label switching of IPv4 packets along normally routed paths is enabled for the platform.
http://www.cisco.com/en/US/docs/ios/mpls/command/reference/mp_m1.html#wp1013428
Hope to help
Giuseppe
