Size Rail KIT
Dec 8th, 2009
What is the length Rail Kit for C360?
What is the Part Number Rail Kit for C360?
steven_geerts Wed, 12/16/2009 - 22:11
The C650 and C350 are a standard Dell PowerEdge 2950 servers, I believe the C360 is using the next hardware model what would be the PowerEdge 2970.
I'm not sure if you can order separate rack-mount kits @Ironport, but i'm sure you can order them @Dell.
good Luck, Steven
