Configuring 2811 for FoIP
Dec 8th, 2009
I have a VIC2-4FXO module that will be inserted into a 2811 router for FoIP Anybody have any ideas on how to configure this bad boy to make it work with our Fax server that is going to be in a virutual environement?
J
paolo bevilacqua Fri, 12/11/2009 - 07:41
  • Hall of Fame,
    Founding Member
You are not giving enough detail about what you want to do.
julienf28 Fri, 12/11/2009 - 10:53
This is a great doc and we do have CUCM7.X but we are using Captaris RightFax server for the time being.
We are thinking of maybe going to UCM once our service contract is finished with Captaris.
Julien
Jerry Ye Fri, 12/11/2009 - 11:01
  • Cisco Employee,
I understand your are using Captaris RightFax server which is the same as Cisco Fax Server (Cisco OEM that from Captaris/Opentext). You can use that doc for call control. What that really does is when a fax call is received from the GW, it will use the CM to process the call, and the RightFax server is talking to CM via H.323 trunk. So this way, you have a single point for incoming and outgoing call processing via CM.
jerry
