12-08-2009 09:11 AM - edited 03-06-2019 08:52 AM
Is per-source CEF load sharing supported or will it be supported in IOS? Thanks.
12-08-2009 09:35 AM
If you do not want to use the universal algorithm, then you can use this command to change it.
ip cef load-sharing algorithm
http://www.cisco.com/en/US/docs/ios/ipswitch/command/reference/isw_i1.html#wp1011833
Reza
12-08-2009 09:56 AM
Looks like per-source CEF load sharing is not supported yet. Just want to know if Cisco has a plan to add per-source CEF load sharing. PBR (source based routing) load sharing can achieve similar goal in some case, but per-source CEF load sharing is NOT replaceable.
