Unity Connection 7.X Migration from Unity 4.2 (COBRAS) Error on Restore Messages
Dec 8th, 2009
Hello Experts!
I'm currently dealing with an error on the COBRA migration when is comes to restoring the Messages on the mailboxes.
I'm testing with one user for the moment.  Port 25 is open on both Unity Connection and the machine that I'm migration from.
The error is the following:
12/7/2009 3:40:15 PM:         Restoring message # 1
12/7/2009 3:40:16 PM:     Copying WAV file raw to upload loation:C:\Program Files\Cisco Systems\COBRAS\Import_CUC\MsgRestore\VoiceMessage.wav
12/7/2009 3:40:16 PM:                Sender alias not found:UNITY_PWAT1VM01 - message will be left as outside caller
12/7/2009 3:40:16 PM:             FromAlias='UNITY_PWAT1VM01', SenderANI='4163067746', Subject=Message from an unidentified caller (4163067746)
12/7/2009 3:40:16 PM:         Restoring message # 2
12/7/2009 3:40:16 PM:             FromAlias='UNITY_PWAT1VM01', SenderANI='4163067743', Subject=Message from an unidentified caller (4163067743)
12/7/2009 3:40:16 PM: (error) failure sending email message via SMTP for message with subject=Message from an unidentified caller (4163067743) in SendMessageToServer_CUC.
12/7/2009 3:40:16 PM: (error) failure returned from IMAP library=ChilkatLog:
  SendEmail:
    DllDate: Sep  8 2009
    UnlockPrefix: CISCOMAILQ
    Username: Administrator
    Component: ActiveX
    Recipients:
      NumTo: 1
      To: [email protected]
      NumCC: 0
      NumBCC: 0
    Sending RSET command..
    Using existing/open SMTP connection to send email.
    ConnectionType: Unencrypted TCP/IP
    subject: Message from an unidentified caller (4163067743)
    reversePath: unityconnection
    503 5.5.0 Sender already specified.
    Failed when sending MAIL FROM:<unityconnection>
    RSET
250 2.0.0 Reset State
    NumSuccess: 0
    NumTotal: 0
    Send failed.
  503
Please note the line in Bold.... I suspect there is my problem but I don't know how to proceed.
Any comments?
Thank you very much in advance!
Hoan Mai Wed, 12/09/2009 - 13:21
Make sure you check the followings -
1. Stopped all the 3rd party anti-virus applications and firewall running on your PC.
2. Restarted SMTP server within connection manager Serviceability.
Hope this helps.
lindborg Thu, 12/10/2009 - 11:02
Also, be sure to check out the help file (I'm assuming you're at the latest version of COBRAS import) - there's a section in there titled "troubleshooting tips" and it has a section in there specifically for message transport.  In it you'll see that port 25 is not the whole story - HTTP is used for transfernig wav files and other ports ar at play.  So far 100% of the message transport problems reported to me have been either the security settings being wrong in Connection or a firewall/security app on the client side blocking it.
