12-08-2009 02:50 PM - edited 02-21-2020 03:49 AM
Hi, need to setup syslog server that will receive logs from an ASA firewall. Firewall has multi contexts and wondering how the syslog should be setup in this case? One syslog config for all context (from admin context) or individual syslog setups from every context.
12-10-2009 04:37 PM
Any ideas or was the question too hard? :-)
12-16-2009 11:10 AM
Each context should be able to ping (basic connectivity) the syslog server and then you set syslogging on each context separately and that should work.
Each context is a separate firewall so it need syslog config separately.
I hope it helps.
PK
