Managing User Remote VPN Access
Dec 8th, 2009
Hi all,
I have a cisco ASA 5505 which uses an LDAP AAA Server group as a user database.
My question is, by denying Dial -In access in Active Directory, or by controlling access using Remote Access Policy, will the ASA accept/deny logons? or do I have to set up 802.1x RADIUS authentication of some sorts?
kush.sri2001 Wed, 12/09/2009 - 21:09
Hi Mario,
You can control the VPN access to users using the Remote Dial-in permissions of the Active Directory. If you are using the ASA for VPN authentication using LDAP, you can check the following articles for the same:
For configuration using the ASDM:
For configuration using the CLI:
