12-08-2009 04:30 PM - edited 03-06-2019 08:52 AM
we have two routes for one of the destination. But i am not able to see one route in my topology table., what might be the cause.Thanks in advance.
Routing protocol : Eigrp
12-08-2009 04:37 PM
Could you be more specific.
Do you mean you have 2 equal cost path routes but you are only seeing one in the routing table
OR
do you mean you have 2 routes to a destination but when you look at the topology table you only see on route. If so are you using the command "sh ip eigrp topoology all-links" because without the all-links you will only see the successor and feasible successor routes.
Jon
12-08-2009 04:42 PM
yes, i have 2 routes to a destination but when i look at the topology table i can see only one route...
12-08-2009 04:43 PM
What command are you using to look at the topology table ?
Jon
12-08-2009 04:48 PM
sh ip eigrp top xx.xx.xx.xx mask
12-08-2009 04:53 PM
Could you read my original post about "sh ip eigrp topology all-links"
Jon
12-09-2009 08:20 AM
Jon
Hi Jon,
I am not sure if this is IOS specific but on most of the IOS versions that I have tried the 'show ip eigrp topo
12-09-2009 12:59 PM
Hi jon,
The route is not available only for particular destination , I can see it in sh ip eigrp top
12-09-2009 01:05 PM
vdadlaney wrote:
Jon
Hi Jon,
' displays all the routes not just the feasible successor. I believe the "show ip eigrp top all-links" command is equal to the "show ip eigpr top" without specifying the actual network and mask. Appreciate if you can can confirm if you know otherwise as I have always used the show ip eigrp top to troubleshoot such scenarios. thx for your help.
Must admit from memory i thought that only the all-links and detail-links options showed all routes learnt via EIGRP. You've got me thinking now so i'll have to lab it up and get back to you
Jon
