Configuration Check-up for H-QoS on ES 20 in C7600
Dec 9th, 2009
We would like to apply the following configuration on the C7600 ES Card,
class-map match-all aaa-Voice
  match ip precedence 5
class-map match-all aaa-Gold
  match ip precedence 4
class-map match-all aaa-Silver
  match ip precedence 3
policy-map aaa-QUEUEING-1M
  class aaa-Gold
    bandwidth 160
  class aaa-Silver
    bandwidth 160
  class class-default
    random-detect aggregate
policy-map aaa-SHAPING-1M
  class aaa-Voice
    priority 380
  class class-default
    shape average 620000
    service-policy aaa-QUEUEING-1M
We placed the aaa-voice class to Parenets policy-map in the SHAPING-1M, because of delay,
If the aaa-voce is in the child aaa-QUEUEING-1m, There must be the delay due to Parenets Shaping priority
I applied the above configuration in the Cisco 3660 router, there was no problem to apply "service-policy output aaa-SHAPING-1M"
but the problem is that When I apply above the configuration on ES card in C7600, the error message was occured,
the error message is "
Child policy on class-default is not
supported with other classes on the parent level for main-interface " in the interface x/x/x
How Can I achive the main gole?
Our main gole is that the voice is the best effort to delivery the traffic and has no delay, but data don' t care in delay.
We must apply the configuration on ES 20 in 7600 Router.
Thanks in advance.
Giuseppe Larosa Wed, 12/09/2009 - 02:05
  • Hall of Fame,
    Founding Member
Hello Syjeon,
the error message informs that it is not possible to attach a child policy to class class-default.
In this case you should create a class where you put all IP traffic, be aware that order is important so that this class has to be invoked as last in the policy-map.
class mydefault
The idea is to deplete class class_default to overcome this limitation.
Hope to help
Giuseppe
Related Content
