Can't Drag N' Drop files in CCA 2.2
Dec 9th, 2009
I have apparently problems with dragging files in CCA release 2.2. I've tried to put the translation file for the CP-524 by Drag n Drop file to UC520 icon in the CCA 2.2 without success. I then tried the CCA version 2.1 which worked without any problems ...
Could it be a bug in the CCA 2.2 or has this feature been removed with the new layout of topology view.
Cheers
Henrik
Steven DiStefano Wed, 12/09/2009 - 05:22
Hi.
I tried it.  While I did see the little black circle on the UC540 ICON when I dragged the SPA525G phone load onto it, When I let it go, a TFTP pop up did ipen and it did put the .bin on my flash.
Problem for phone loads, is it needs to do alot more;
- tftp-server statements
- telephony-service load statement
- create cnf for the phone loads
- place the file in the appropriate sub directory
It didnt do any of there.
I reported to CCA team.  They will addres this in the next release of CCA I was told.   We want to see it support all phone loads in the bundle, but it is not clear if it will support all phone types at this point.   I know for sure the SPA500 will be....
Steve
