12-09-2009 03:10 AM
When creating a job report from a User defined group ex 1000 devices. When then making a new device discovery and its finding ex 2 devices and adding it to the user defined Group.
Do the scheduled job report understand 2 more devices are found or do i need to re create the job resport so the 2 new devices will be added?
12-09-2009 06:03 AM
I beleive it takes a list of device_ID's on the moment you schedule the job.
These are device_ID's are the internal number of the device in the DCR.
I noticed once while running a job that it also tried removed devices and crashed because the job couldn't find the devices matching the device_ID.
So in your case your job should start when the discovery is done. Not before.
Cheers,
Michel
12-09-2009 06:22 AM
12-09-2009 06:29 AM
maybe i misunderstood your question. Sorry, its the flu I huess
If the user defined group is of the type "dynamic" then yes if it is "static" then no
Cheers,
Michel
12-09-2009 06:43 AM
