GBIC
Answered Question
Dec 9th, 2009
Hi Friends:
I have some doubt to find & confirm the part number of a GBIC port module. On 6509 switch we have a SFP module (WS-X6724-SFP). I want to know the part number of the GBIC port inserted to it. Whether it is a SX or LX type.
This switch is in remote location. Thats why I couldn't check physically.
Any suggestion here pls?
Thanks!!
Arun
Correct Answer by vvasisth about 7 years 4 months ago
yup the part number will be GLC-SX-MM
Check this you will get all the information regarding the SFp connectors :-
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Chassis_Installation/Cat6500/0bcabcon.html
regards,
Varun
Correct Answer by Jon Marshall about 7 years 4 months ago
arun.patro wrote:
Thanks Jon,
So the exact part number will be GLC-SX-MM?
Regds.
Arun
Yes that should do it, this is the standard connector for multimode fibre connection.
Jon
Overall Rating: 5 (2 ratings)
Giuseppe Larosa Wed, 12/09/2009 - 03:26
  • Hall of Fame,
    Founding Member
Hello Arun,
that is a linecard and SFP can be different on each port
use show interface status on the righmost column it will give you for each port the type of GBIC installed
example:
T-TO-CRN-SF-E-1>sh int status
Port         Name               Status       Vlan       Duplex  Speed Type
Gi3/1        Link -> XX-CRN- connected    10           full   1000 1000BaseSX
Gi3/2        XX-SM-C-3   connected    trunk        full   1000 1000BaseSX
Gi3/3        XX-SM-C-1g1 connected    trunk        full   1000 1000BaseSX
Hope to help
Giuseppe
Jon Marshall Wed, 12/09/2009 - 03:28
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Arun
You need an SFP type connector, see this page for details -
6500 SFP connectors
Jon
vvasisth Wed, 12/09/2009 - 03:29
  • Silver, 250 points or more
"Show interface " will give you this result as well as "sh idprom int "
example :-
sup720_52#sh idprom int gi9/4 detail
Hexadecimal dump of TRANSCEIVER SEPROM :
       SEEPROM contents (hex) size 128:
         0x00: 03 04 07 00 00 00 01 00 00 00 00 01 0D 00 00 00
         0x10: 37 1B 00 00 43 49 53 43 4F 2D 46 49 4E 49 53 41
         0x20: 52 20 20 20 00 00 90 65 46 54 52 4A 38 35 31 39
         0x30: 50 31 42 4E 4C 2D 43 36 41 20 20 20 03 52 00 74
         0x40: 00 1A 00 00 46 4E 53 31 31 33 36 31 39 30 31 20
         0x50: 20 20 20 20 30 37 30 39 30 37 20 20 58 80 01 87
         0x60: 00 00 02 D6 ED 72 04 68 64 6B 3D 7B FB 59 4B 3C
         0x70: 18 60 AA 00 00 00 00 00 00 00 00 00 2C 3B 6C 49
Transceiver Serial EEPROM Contents:
Common block:
Identifier        : SFP [0x03]
Connector         : LC [0x07]
Transceiver
Speed            : Unspecified [0x00]
Media            : Unspecified [0x00]
Technology       : Unspecified [0x00]
Link Length      : [0x01]
GE Comp Codes    : Unspecified [0x00]
SONET Comp Codes : Unspecified [0x00]
Encoding          : 8B10B [0x01]
BR, Nominal       : 13x100 MHz [0x0D]
Length(9u)        : Transceiver does not support single mode fibre,
                    or the length information must be determined from
                    the transceiver technology. [0x00]
Length(50u)       : Transceiver does not support 50 micron multi-mode
fibre,
                    the transceiver technology. [0x37]
Length(62.5u)     : Transceiver does not support 62.5 micron multi-mode
fibre,
                    the transceiver technology. [0x1B]
Length(Copper)    : Transceiver does not support copper cables,
Vendor Name       : CISCO-FINISAR
Vendor OUI        : 00.90.65
Vendor PN         : FTRJ8519P1BNL-C6
Vendor rev        : A
CC_BASE           : 0x74
Extended ID Fields
Options           : Loss of Signal implemented
                    TX_FAULT signal implemented
                    TX_DISABLE is implemented and disables the serial
output
BR, max           : Unspecified 0%
BR, min           : Unspecified 0%
Vendor SN         : FNS11361901
Date (yy/mm/dd)   : 07/09/07
CC_EXT            : 0x87
Vendor Specific ID Fields:
0x00: 00 00 02 D6 ED 72 04 68 64 6B 3D 7B FB 59 4B 3C
0x10: 18 60 AA 00 00 00 00 00 00 00 00 00 2C 3B 6C 49
arun.patro Wed, 12/09/2009 - 03:40
Hi Friends:
Thanks for all the quick commects.
Here I have attached the interface outputs.. Still not sure about the part number either it is GLC-SX-MM ot GLC-LX-MM
Jon Marshall Wed, 12/09/2009 - 03:43
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
arun.patro wrote:
Hi Friends:
Arun
You want SX - from your interface output -
Full-duplex, 1000Mb/s, media type is SX
Jon
arun.patro Wed, 12/09/2009 - 03:47
Thanks Jon,
Regds.
Arun
Correct Answer
Jon Marshall Wed, 12/09/2009 - 03:54
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
arun.patro wrote:
Thanks Jon,
Regds.
Arun
Jon
