Unity Message Monitoring Delay
Answered Question
Dec 9th, 2009
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
I have recently enabled Unity message monitoring on V5.x for a customer and they are saying that when you call someone with it enabled there is approx 5 sec delay before you hear the mailbox greeting played, is this normal or is there a way to reduced the time 5 sec delay?
Any pointers would be very helpful
Thanks in advance
Correct Answer by Rob Huffman about 7 years 6 months ago
This is the related bug;
Message Monitor: When configured delay in hearing greeting.
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsi80906&Submit=Search
CSCsi80906 Bug Details
MM:when config'd delay in hearing greeting
Symptom:
When Message Monitor is configured for a subscriber's phone, the caller hears a delay after the call is forwarded to Unity but before the caller hears the subscriber's greeting.
Conditions:
Unity 5.0(1) or later.
Message Monitor is configured for the subscriber's phone.
Workaround:
The delay can be reduced to 3-4 seconds by applying the latest Unity 5.0(1) ES, or by upgrading to Unity 7.0(1). However, there not a way to reduce the delay beyond this point.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Wed, 12/09/2009 - 06:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Symptom:
Conditions:
Workaround:
Hope this helps!
Rob
e.parsonage Wed, 12/09/2009 - 06:36
Thanks Rob for your speedy reply,
I will now go back to the customer and see if they want to upgrade for the gain of  1-2 seconds !!
E
