Cisco LMS 3.1 In LMS devices deleted in Common Services are still refelecting in RME database.Pls let me know the reason why the devices are still seen in RME?How to overcome this issue.
mvnaveenforever
Cisco LMS 3.1 In LMS --Devices deleted in Common Services are still refelecting in RME database.Pls let me know the reason why the devices are still seen in RME?How to overcome this issue.
Joe Clarke
This is most likely a cosmetic problem.  You could reinitialize the RME database, but that is probably overkill.  There are some pointed databsae queries which can be executed to remove phantom devices, but you will need to open a TAC service request to get that procedure.
