NTP Server question
Dec 9th, 2009
Hello
I have recently setup a medium size network with around 70 switches and I am now getting to the point where I need to configure the time on those switches. I understand that I need to identify a device to use as NTP server. We don't currently have a spare router so the option is to buy one to use solely as NTP server. Does any of you know the cheapest cisco model i could get as it would be a waste to get an expensive one just to use as NTP server unless there is another way that does not involve getting a Router. Also can I use a windows server as an NTP server to use with switches?
Thanks.
Reza Sharifi Wed, 12/09/2009 - 07:40
  • Cisco Designated VIP,
    2017 LAN
Since you have a small to medium size network you can use a couple of servers and set them up as NTP servers.  Then use the Internet or other authoritative source for your NTP server to synchronize their time. Then have all your network equipment synchronize their time to theses servers.
Reza
raoul2341 Thu, 12/10/2009 - 01:26
Hello Reza et al
Many thanks for your reply.
We have a PDC emulator that is configured as an ntp server. On a switch, I have entered the command "ntp server ip_address_of_ntp_server" in config mode but the time on the switch is not synchronised. Am I missing something?
vinodsharma7 Thu, 12/10/2009 - 01:33
Did you configure timzone coorectly on your switch and did you verify connectivity from your switch to NTP server is fine?
thanks
vinod
raoul2341 Thu, 12/10/2009 - 02:36
Hi Vinod
The answer is yes to both your questions but the time on switch does not synchronise.
Thanks.
vinodsharma7 Thu, 12/10/2009 - 03:25
Could you please provide the output of the followin commands.
show ntp associations
show clock detail
thanks
Vinod
raoul2341 Thu, 12/10/2009 - 06:07
Here are the details:
      address         ref clock     st  when  poll reach  delay  offset    disp
~10.221.27.83    10.221.16.101     3   819  1024  377     0.7  132754   220.4
* master (synced), # master (unsynced), + selected, - candidate, ~ configured
sh clo detail
.13:42:06.659 GMT Thu Dec 10 2009
Time source is NTP
Summer time starts 01:00:00 GMT Sun Mar 28 2010
Summer time ends 02:00:00 GMT Sun Oct 31 2010
The time on the ntp server is 14:05
Thanks.
