Upgrade hybrid 6500
Dec 9th, 2009
I am trying to find if there are any issues in upgrading hybrid 6500 in one reload. We plan to put the IOS on MSFC and CATOS on SUP, change the boot statements and reload the device. Is this expected to work good?
Thank you!!
pfillips11 Wed, 12/09/2009 - 08:09
Thank you.
But the currently native mode is not an option.
pfillips11 Wed, 12/09/2009 - 19:06
Thank you.
The version that we are planning to upgrade is 8.6. Under 8.x version there are no compatible images for using highavailability versioning.
The device is currently at 7.4(2) CATOS and IOS 12.1(8b)E11. The plan is to put 8.6(4) and 12.1(27b)E4 in respective bootflash (SUP2) .... change the boot statements and reload. Is this expected to work? Unfortunately don't have a test lab....
Giuseppe Larosa Wed, 12/09/2009 - 22:39
  • Hall of Fame,
    Founding Member
you will need a maintanance window because without high availability the system should fall back to fast switchover that is slower and it takes the time to reload both supervisors (and their MSFCs).
Hope to help
Giuseppe
