1131 AP Shows as having "other" antenna in the WCS
Nael Mohammad Thu, 12/17/2009 - 09:58
  • Silver, 250 points or more
1. You can go to Monitor Map ---> Campus ---> Select Building ---> Select Floor ---> From the drop down menu select command, choose "Position AP" and Go .
2. Click on the problematic AP's 1131 and select the correct Antenna type as being "AJAX-OMNI" which the image should match for AIR-LAP1131AG-A-K9.
3. Click Save and the heat map should start to populate.
4. From Floor Settings, select Access Points --> Protocol "802.11b/g/n" or 802.11a/n but not both. It's has to be one or the other else the heat maps will not display.
5. From Floor Settings ---> AP Heatmaps --> Contributing APs, Select ALL the APs and OK.
-nael
