Agent Desktop Error when CCM1 server fails..
hi,
I have configured IPCCX in HA environment.. so there are two CCM servers (CCM1 and CCM2) and two IPCCX servers (IPCCX1 and IPCCX2)..i have configured extension mobility service in redundant mode...I also associated the phone with RM JTAPI provider.. every thing works fine when both ccm servers are up, means agent are able to login to both phone and the agent desktop.. but when i remove the network cable of CCM1. the phone successfully login (after some delay)..  but agent desktop gives the following error..
"Login failed due to configuration error.. please ask your system administrator to associate your phone with the rmjtapi provider user id according to the instruction in the administrator guide"
Even though i have associated the RM CM Jtapi provider with the phone... this situation only occurs when i down the ccm1 server.. if both servers are up every thing works fine.... any idea about it...
Naresh Rathore
karnakumar Wed, 12/09/2009 - 16:08
In UCCX, check the Cisco Unified CM Telephony Subsystem - Cisco Unified CM Telephony Provider Configuration, add the both CM's IP address and make sure that CTI Manager service runing on both CM's.
Rajiv Lal Tue, 12/22/2009 - 11:57
It sounds that call manager replication issue.
Please check if the DB replication between the call manager is good.
Rajiv
