vtp
Answered Question
Dec 9th, 2009
I've got 2 3750 switches in a secure vtp domain - one is vtp server, the other vtp client.  I'd like to manage both switches separately with no vlan propagation between them, i.e. not use vtp at all.
Is there a way to reconfigure the switches such that they are no longer using vtp but retain all the existing VLAN information or would removing the vtp config and setting both to transparent mode wipe any existing existing vlans that were set up when the switches were in a vtp domain.
Correct Answer by dlawson001 about 7 years 7 months ago
Just verified this in my lab. The vlans on the client switch will remain on the switch when converted to transparent.
Correct Answer by Jon Marshall about 7 years 7 months ago
Dave
If you convert the switches to VTP transparent then the switch will write it's vlan database to the running config so you should be fine.
Jon
Correct Answer by Reza Sharifi about 7 years 7 months ago
Hi Dave,
Nothing will happen to existing vlan database in a switch when it transitions from client to transparent.
Have look at this:
https://learningnetwork.cisco.com/thread/4626
Reza
Overall Rating: 5 (3 ratings)
Correct Answer
Jon Marshall Wed, 12/09/2009 - 09:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Dave
Jon
Correct Answer
dlawson001 Wed, 12/09/2009 - 10:40
