Using TACACS+ from a v6.0 WLC to v5.1 ACS
Answered Question
Dec 9th, 2009
  • Silver, 250 points or more
Hi All,
I'm trying to setup TACACS+ a WLC (v6.0.188.0), to a v5.1 ACS.  I've got all the ACS policies setup for integration with AD, Group Mapping, etc... and that all works fine, the problem is that the 'Shell Profile' and/or 'Command Set' I'm using doesn't suitably authorise the user, and so the WLC doesn't let them on... A success / access-accept message is generated and transmitted, but as far as the WLC is concerned it doesn't contain the necessary rights, so the admin doesn't get on.
I am aware of the requirements and how to create this in ACS 4.x, but 5.1 is a different beast and I can't find the necessary bits in the ACS 5.1 GUI to create the config.
Does anybody know how to create the equivalent configuration in ACS 5.1?
Basically need to work out how to do this;
PPP IP
Shell (exec)
Service = ciscowlc, Protocol = common
  Custom Attributes:
  role1=ALL
Any help, much appreciated!!
Cheers,
Richard
Correct Answer by Michael Langerreiter about 7 years 4 months ago
Richard!
The shell profile for the different wcs roles works - thanks a lot for your help!
Even the shell profile for my WLCs works with role1=ALL. I also confirmed it with role1=WLAN.
You seem to use role=ALL, maybe you should give role1=ALL a try?
Mike
Hi!
I'm trying the same thing for my WLCs and I would also like to do my WCS authentication and authorization via ACS 5.1 (for admin and lobby ambassador access)
I also know how to configure ACS 4.2 to hand out the custom attributes ("Interface Configuration" --> "TACACS+ (Cisco)" --> "New Services" ciscowlc/common for the WLCs and Wireless-WCS/HTTP for WCS. Appropriate roleX=Y strings in the group settings), but have no clue how do the same thing with ACS 5.1.
Any ideas anyone?
Michael
Overall Rating: 5 (6 ratings)
Correct Answer
Michael Langerreiter Thu, 12/10/2009 - 01:27
Hi!
Any ideas anyone?
Michael
Richard Atkin Thu, 12/10/2009 - 01:47
You can do the WCS Authorisation by doing this;
Go to Policy Elements > Authorisation & Permissions > Device Administration > Shell Profiles
Create a new Shell profile for WCS
Go to the Custom Attributes for your WCS Shell Profile
You have then have three fields to populate, Attribute, Requirements & Value, you have to create one entry for each WCS Role / Task. Ie,
Attribute = role0
Requirements = Mandatory
Value = Root
Attribute = task0
Value = Users and Groups
Attribute = task1
Value = Audit Trails
etc...
There are about 69 entries to make in total so it takes a little while...  Once complete you then just need to reference the WCS Shell Profile in the relevant Authorisation Profile.
Back to the original problem, this doesn't seem to work for the WLC, where I tried the following with no success.
Attribute = role
Value = ALL
Cheers,
Richard
Correct Answer
Michael Langerreiter Thu, 12/10/2009 - 06:14
Richard!
Mike
Richard Atkin Thu, 12/10/2009 - 06:38
Mike, thank you!
It's been a long week here, I knew it would be something simple!!
Thanks for the pointer, glad you got WCS working too...
Richard
hugh.turner Fri, 08/06/2010 - 08:55
Hi... just reading the post and I have the same issue trying to use TACACS to authenticate users to log into a 5508 WLC. I'm also using ACS 5.1.
Can you clarify what exactly needs to be in the shell profile for me, I'm a little confused.
So far I have created a brand new shell profle and applied it be used when a user connects to a WLC.
All I have added to it is one custom attribute:
Attribute: role1
Requirement: Mandatory
Value: ALL
I've not put anything in the common tasks.  Do I need to?
I must have something I'm missing, since the WLC just rejects me and repeats it's request for a log on.
LUCAS NEEDHAM Fri, 05/07/2010 - 11:56
role1=ALL did the trick for me.  Thanks for this post.  You saved me a TAC case!
c.yeo Mon, 01/04/2010 - 14:28
We've been struggling with ACS 5.0 and not getting anywhere.
I think we're missing some 'concepts'.
You mention 3 fields to populate....I don't see anything like that:
When I create a WCS Profile, I only see Name and Description on the General Tab, and two other tabs" Privilege and Shell Attributes.
It appears I am looking in the wrong places.
Our exact version of ACS is:  5.0.0.21
Can you shed any light on what we are supposed to see?
Charles
Richard Atkin Tue, 01/05/2010 - 01:46
Cisco don't recommend using ACS v5.0, as frankly, it's crap.  The upgrade to v5.1 is a free download off CCO...
Rgds,
Richard
volven.didata Tue, 04/06/2010 - 23:09
Hi All,
I tried integrating the WCS 6.0 with ACS 5.1 using TACACS but unable to login, I get the following error " [AuthenticationAction] User has no usergroups/roles assigned. Username= lobadmin "
Note - I have created the Shell Profile and added the following custom attibutes...
Attribute               Requirement               Value
role0                    Mandatory           LobbyAmbassador
task0                   Mandatory           Configure Guest Users
task1                   Mandatory           Lobby Ambassador User Preferences
Is there anything else i need to do?
Volven
Related Content
Trending Topics - Security & Network
