PIX change management software
Dec 9th, 2009
Hi, i have Cisco works LMS3.0,
i have added all routers switches, and after every 24 hours, all changes to my routers switches, i get that via email,
but i dont see any change report of cisco pix firewall.
dont LMS3.0 support firewall changes ? am i missing some thing? or i need some other software to do that?
ahmad82pkn Tue, 12/15/2009 - 15:32
Thank you for the information, But i dont get change report , though devices are added in same way as of Routers,
Do i need to do any additional confoguration on firewall, except SNMP string and specifying IP address of server running LMS and its interface name inside in my case?
in my PIX i have this confoguration, router confoguration change report comes fine, with same set of information configured in router/switches.
snmp-server host inside x.x.x.x community abcd
snmp-server community abcd
Farrukh Haroon Tue, 12/15/2009 - 22:17
  • Red, 2250 points or more
Do one thing, go to the Device Center >> Select the 'Firewall' and then click on 'View Config' Is RME collecting any
configs at all for your firewall?  You can also check this from RME directly.
Farrukh
