Troubleshooting AD accounts with CUCM 7.1.2
Dec 9th, 2009
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Hello I would like to know where I would go to find out if I have having synchronization issues with MS AD. I created an account in AD yesterday and I preformed a full sync this morning (as well as each night) but I am still not able to search CUCM for this user. I have logged into my workstation with this user account to make sure that it was active in AD.  I would like to know where a good place to look for errors/debug for synchronization would be.
Any pointers would be appreciated.
Overall Rating: 5 (1 ratings)
Ginger Dillon Wed, 12/09/2009 - 10:36
  • Blue, 1500 points or more
Hi -
The first thing I would check is where the user account is being created within AD, meaning which Organizational Unit (OU) and has a last name.  Users without last names in AD will not be imported.  Then check your LDAP synchronization in CUCM to ensure you have the right user search base.  The search base needs to include the OU where the user account is created.  Make sure you don't have an existing Application User in CUCM with the same name as the user also.  Here is a good reference doc related to CUCM user search base and configuration - http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/directry.html#wp1044981
Sincerely, Ginger
John Palmason Wed, 12/09/2009 - 10:45
Thanks Ginger, you where right on with the Last name, my AD team didn't fill in first or last name for the account. Once that was done, I resync'd the LDAP connection and the account appeared.
Thanks again.
John
Ginger Dillon Wed, 12/09/2009 - 10:48
Hi John -
Great news!  Glad I could help :-)
Ginger
