Star codes on the IP phones?!?
Answered Question
Dec 9th, 2009
  • Silver, 250 points or more
I got a question about star codes on the cisco uc500. One of our "older" technitions are used to working with traditional pbx´s and they could use star codes to perform certain functions, like "star code" to redial last call, etc. I know this is a softkey on the UC, but it was an example :)
The question is really if it´s possible to put one of these codes on availiable line key on the phone and name the button to whatever and have it do something within the star code commands?!?
Eivind
Correct Answer by ttrentler about 7 years 5 months ago
The Feature Access Codes can be assigned buttons using a speed dial once they are enabled from within telephony-service configuration mode.  You can also create your own custom FAC codes with the fac custom command
Correct Answer by Steven DiStefano about 7 years 5 months ago
Not sure about assigning to a line button, but you can 'dial' FACs.
To see the ones you get, out of the box, do show telephony-service fac:
UC540#show teleph
UC540#show telephony-service fac
  telephony-service fac standard
    callfwd all **1
    callfwd cancel **2
    pickup local **3
    pickup group **4
    pickup direct **5
    park **6
    dnd **7
    redial **8
    voicemail **9
    ephone-hunt join *3
    ephone-hunt cancel #3
    ephone-hunt hlog *4
    ephone-hunt hlog-phone *5
    trnsfvm *6
    dpark-retrieval *0
    cancel call waiting *1
Overall Rating: 5 (2 ratings)
Correct Answer
Steven DiStefano Wed, 12/09/2009 - 13:51
  • Blue, 1500 points or more
UC540#show teleph
    callfwd all **1
    callfwd cancel **2
    pickup local **3
    pickup group **4
    pickup direct **5
    park **6
    dnd **7
    redial **8
    voicemail **9
    ephone-hunt join *3
    ephone-hunt hlog *4
    trnsfvm *6
    dpark-retrieval *0
Correct Answer
ttrentler Thu, 12/10/2009 - 17:33
Eivind Jonassen Fri, 12/11/2009 - 02:16
Thanks, but the I get the following from my UC;
UC_telec#sh telephony-service fac
UC_telec#
Any ideas?
Got IOS uc500-advipservicesk9-mz.124-20.T2
Eivind
Steven DiStefano Fri, 12/11/2009 - 04:09
This is fixed in CCA 2.2 (we configure this for you)
for now do it manually
UC540#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
UC540(config)#telep
UC540(config)#telephony-service
UC540(config-telephony)#fac ?
  custom    Select customized feature access code
  standard  Select standard feature access code
UC540(config-telephony)#fac s
UC540(config-telephony)#fac standard
fac standard is set!
UC540(config-telephony)#do show telephony-service fac
    callfwd all **1
    callfwd cancel **2
    pickup local **3
    pickup group **4
    pickup direct **5
    park **6
    dnd **7
    redial **8
    voicemail **9
    ephone-hunt join *3
    ephone-hunt hlog *4
    trnsfvm *6
    dpark-retrieval *0
Related Content
