question for linux users - SOLVED!
Answered Question
Dec 9th, 2009
What if anything do you use to compare 2 or more configs? I've used software called HyperConf (awesome program) under windows but it will not install into Ubuntu(yea I tried wine). it displays 2 configs side by side and will show differences with color, different colors mean different things. Its very simple, and I use it at work pretty regularly, however I'm a linux user outside the office and want something similar for my Ubuntu laptop.
Any comments are welcome, thank you all
Message was edited by: Richard Calvert
Correct Answer by marikakis about 7 years 4 months ago
Meld Diff Viewer is a very popular graphical diff program. You can compare 2 or 3 files. After installation (sudo apt-get install meld), you can run the viewer from CLI (meld &) or find it under Applications->Programming->Meld Diff Viewer.
Overall Rating: 4 (2 ratings)
Conor Cunningham Wed, 12/09/2009 - 10:05
Richard,
Check out diff for comparing 2 files and diff3 for comparing three files. They are standard command line tools. I'm not sure how you install things  in Ubuntu, but I think it is apt-get install. So, if you don't have diff, try
sudo apt-get install diff.
Let me know if that helps.
Cheers,
Conor
Correct Answer
marikakis Wed, 12/09/2009 - 11:05
  • Gold, 750 points or more
ubuntu_guy Wed, 12/09/2009 - 12:01
Diff is what I've found so far and I've found it to be lacking based on the format of the output. I'm installing Meld Diff.
Related Content
