12-09-2009 01:14 PM - edited 03-14-2019 04:58 AM
Hello;
If I have two ICM's and two Call Managers, the first call manager communicate with first ICM, and the second call manager communication with second ICM, what is the possibility to let the first ICM communicate with the second call manager (in addition that it is communicated with first call manager), and to let the second ICM to communicate with the first call manager (in addition that it is communicated with the second call manager)?
Is it possible? Just need to establish the JTABI and it is going to work? So when agent logged in via the first communication manager, then both ICM's will know this? If yes, then if the agent busy (as one ICM route a call for it, this will be cleared for the other ICM)?
Any advise?
Bilal
12-09-2009 05:52 PM
When you say two call managers, do you mean two subscribers within the same cluster, or two different clusters? You cannot connect one ICM to two different clusters unless you have one UCM PG for each. If you are talking about two different subscribers, then technically yes two different PG's from two different ICM's can connect to the same subscriber, but it wouldn't be supported for production, each subscriber should only be used by a single PG side. Also you would have to make sure they use different pg users, and you definitely cannot overlap agent devices the way you described.
12-10-2009 03:25 AM
Thanks a lot for your kindly reply.
What does it means:
Unless you have one UCM PG for each cluster?
Also, what do u mean by:
Again, special thanks for your kindly help and advise.
Bilal
12-10-2009 07:04 AM
You can have one ICM instance, with two PGs, the first PG will connect to UCM cluster 1 and the second PG will connect to UCM cluster 2. This is supported.
You could have one ICM instance with two PGs, the first PG will connect to UCM cluster 1 subscriber 1, the second PG will connec to UCM cluster 1 subscriber 2, this is not supported and personally doesn't make any sense as to why anyone would do that.
david
