Recommendation regarding upgrading from CM 5.1(2)
Dec 9th, 2009
We are researching for our upgrade planning and looking for
advice/feedback.  We are currently running the Linux version of call manager 5.1(2).  How stable is the current Linux version of CM 7.1?  I don't think there is an upgrade path from our version to 7.1, any suggestions on how to approach this upgrade.
Any suggestions or feedback would be great.
Thank you.
Rgds,
Vicky
Jaime Valencia Wed, 12/09/2009 - 14:04
Depending on the exact 7.1(x) release the minimum requirement would be 5.1(3), 6.1(2) or 6.1(3). But all depends on the exact release you want to go
Table 4     Supported Cisco Unified Communications Manager Upgrades for Release 7.1(x)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp108792
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
