Why I can not ping the internal network?
Answered Question
Dec 9th, 2009
I have configured a VPN remote access. I can log into my username and password, but I can not ping any computer on the internal network. please helpme...the configuration the router is:
sh run.
aaa new-model
aaa authentication login VPN local
aaa authorization network VPN local
username vpnuser password 0 vpnpass
crypto isakmp policy 1
hash md5
authentication pre-share
group 2
crypto isakmp client configuration group HOME
key 123456!
dns 10.10.10.2
pool VPN-D
include-local-lan
crypto ipsec transform-set TEST esp-des esp-md5-hmac
crypto dynamic-map VPNS 1
set transform-set TEST
reverse-route
crypto map VPNSS client authentication list VPN
crypto map VPNSS isakmp authorization list VPN
crypto map VPNSS client configuration address respond
crypto map VPNSS 1 ipsec-isakmp dynamic VPNS
interface FastEthernet0/0
description ==> Link to ISP <==
ip address dhcp
ip nat outside
crypto map VPNSS
interface FastEthernet0/1
description ==> Red Lan <==
ip nat inside
ip local pool VPN-D 192.168.20.1 192.168.20.20
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 dhcp
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
Correct Answer by Laurent Aubert about 7 years 2 months ago
I assume you are retrieving an IP address from the pool and the route is available in the routing table of the router. In this case you need to tell the router not to NAT the traffic destinated to the VPN client:
ip nat inside source route-map nonat interface FastEthernet0/0 overload
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.20.0 0.0.0.31
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
route-map nonat permit 10
match ip address 101
The following link contains many examples: http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html
Laurent.
Overall Rating: 5 (1 ratings)
Correct Answer
Laurent Aubert Wed, 12/09/2009 - 20:42
Laurent.
