problem installing vpn client on opensuse 11.2
Dec 9th, 2009
When i try to install the  vpn client i allways have this error when i try to compile
Making module
make -C /lib/modules/ SUBDIRS=/download/temp/vpnclient modules
make[1]: Entering directory `/usr/src/linux-'
make -C ../../../linux- O=/usr/src/linux- modules
/usr/src/linux- *** CFLAGS was changed in "/download/temp/vpnclient/Makefile". Fix it to use EXTRA_CFLAGS.  Stop.
make[3]: *** [_module_/download/temp/vpnclient] Error 2
make[2]: *** [sub-make] Error 2
make[1]: *** [all] Error 2
make[1]: Leaving directory `/usr/src/linux-'
make: *** [default] Error 2
Failed to make module "cisco_ipsec.ko".
Any idea
@jsidwell@ Tue, 12/15/2009 - 10:26
There is a site ( that may have the answer that you need.
Here are the steps that may apply to your issue....
5. Do a uname -r to find the correct kernel-headers for your build.
6. Use synaptic to search and install the correct kernel-HEADERS, not source.
7. Untar your Cisco Client, go to the vpnclient folder and do a sudo sh vpn_install
8. Answer all questions, the defaults worked for me.
9. make sure you start the vpn sub-system with
sudo /etc/init.d/vpnclient_init start
10. Copy your .pcf profile to the sudo cp /etc/opt/cisco-vpnclient/Profiles.
11. Do a vpnclient connect (without the .pcf extention)
Hope this helps.
