GLBP - Cat 4506E
onazold
I have a GLBP config consisting of two Cat4506e switches, connecting over 10G fiber to Cat3560E switches. Testing, I have a laptop connected to one of the 3560 switches with a constant ping to the Virtual IP addresses of the GLBP on two different VLANs, and the switches themselves. Both 4500s are configured the same (as seen below). When I reload the .252 switch, I do not lose a packet, but when I reload the .253 switch, I lose about 6 seconds of ICMP. It looks like when the 10G interface comes up, it puts all switchports in a blocking mode. I checked the int. when testing, but it shows it as up/up. Any ideas?
Switch 1 (.252)
interface TenGigabitEthernet2/1
switchport mode trunk
interface TenGigabitEthernet2/2
interface Vlan1
ip address 172.31.7.252 255.255.248.0
glbp 1 ip 172.31.7.250
glbp 1 priority 110
glbp 1 preempt
glbp 1 authentication md5 key-string th1sk3y
interface Vlan20
ip address 192.168.20.2 255.255.255.0
glbp 20 ip 192.168.20.1
glbp 20 priority 110
glbp 20 preempt
glbp 20 authentication md5 key-string th1sk3y
Swtich 2 (.253)
interface Vlan1
ip address 172.31.7.253 255.255.248.0
glbp 1 priority 110
glbp 1 preempt
interface Vlan20
ip address 192.168.20.3 255.255.255.0
glbp 20 preempt
The 3650 switches - both conf. like this
interface TenGigabitEthernet0/1
interface TenGigabitEthernet0/2
Reza Sharifi
Can you add?
switchport trunk allowed vlan
Instead of just
switchport trunk
on all switches?
Also, on the 3560s, do you have port fast enabled on all the access ports?
Reza
Yes, I can (and will) add switchport trunk allowed
On all switches globally I have spanning-tree mode rapid-pvst
Is your comment to allow portfast, or not?
Thanks for you reply.
Yes, enable portfast on all the access ports on the 3560
