Problem using SDM with Site-to-Site VPN Wizard
Dec 9th, 2009
I have a Problem with the Cisco SDM 2.5 Site-to-Site VPN
Wizard. If i click on either 'Create Site-to-Site VPN' or 'Create a Secure GRE' then click on the Launch button, nothing happens. No wizard appears and I also don't get any errors or blocked popups. I have tried several different versions of JRE and also tried reloading SDM 2.4.1 and 2.5 again. I have tried using Firefox or IE7 but still not result. THe wizard will not start. Any suggestions?
I have a 1841 series with IOS 12.4 and SDM 2.5.
Travis Hyde
bapatsubodh Thu, 12/10/2009 - 14:01
It is understandable that VPN configuration is easy with SDM Wizard. We faced similar issue and finally we configured site-to-site
VPN using command line. Believe me it is not very difficult.  Please refer to configuration examples on cisco.com those examples are nice and easy to understand.
Subodh
bcterry1149 Tue, 08/16/2011 - 19:37
The fix for this is to uninstall current java version on local admin machine and install Java 5.0 update 16. I ran into same issue today and this resolved it.
