CSC-SSM File Blocking Scenario
Dec 9th, 2009
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Got a scenario where when a I divert Http Traffic to CSC-SSM, Invalid URL error
Is encountered.  Attached is the network diagram. Users from branch network gets their
Internet connection via the squid proxy of the main branch. The main branch is connected to the branch network via VPN. What we want to accomplish is block audio file using CSC-SSM. Audio/Video File was already selected under
File Blocking(Trend Micro Interscan). But mp3 files can still be downloaded. Upon checking the config,
I noticed that SMTP was the only traffic diverted to the CSC-SSM. So I added
Http Traffic. Below is the config for reference.
access-list outside_mpc_in extended permit tcp any any eq smtp
access-list outside_mpc_in extended permit tcp any any eq http
class-map SMTP
match access-list outside_mpc_in
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect dns maximum-length 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
policy-map outside-policy
class SMTP
  csc fail-open
service-policy global_policy global
service-policy outside-policy interface outside
But upon doing this, all http traffic was blocked. Invalid URL error
Was encountered. If the access-list for http traffic is removed, then
All internet connections are restored but audio file is not blocked.
So it seems that when Http traffic is diverted to CSC-SSM, some
Packet modification takes place that prevents the proxy from
Seing http traffic. Am I Missing something on the configuration?
Here is the error message from the proxy.
The Following Error was encountered
·        Invalid URL
Some Aspect of the requested URL is incorrect. Posible problems:
·        Missing or incorrect access protocol(should be http:// or similar)
·        Missing Hostname
·        Illegal double-escape in the URL-Path
Illegal character in hostname; underscores are not allowed
resoares Thu, 12/10/2009 - 04:31
How does the internet traffic go out from CSC module? The CSC-SSM module will use a Squid proxy to reach the Internet or it has a directly connection ?
I'm asking you this, because there are some proxy settings that can be configured depending on your network topology.
oyd110380 Thu, 12/10/2009 - 23:36
Thanks for the reply. CSC-SSM internet traffic goes through the squid proxy.
resoares Fri, 12/11/2009 - 02:46
Hi, thanks for your update, so configure the CSC to divert the traffic to the Squid.
