ASA 5510
Dec 9th, 2009
Dear All
We have 2 cisco asa 5510 in active passive mode . When i check the failover it shows that both one asa is in active mode and the other  is in passive mode.
I am able to login to the primary firewall but not able to login to secondary . The secondary firewall prompts me for the username /password but does not display anything when i give my credentials
Kindly help
Umesh
ayman emara Thu, 12/10/2009 - 05:23
You won't be able to login to the secondary ASA as it is in passive move
if you want to access it force the secondary firewall to be the primary on and you also won't get access to the other one.
you only allowed to access on of them.
Vikram_Anumukonda_2 Thu, 12/10/2009 - 05:30
it is possible to login to the standby device using the standby ip address. check the logs as to why you are not able to connect to it.
Kureli Sankar Thu, 12/10/2009 - 13:49
  • Cisco Employee,
Are you trying to telnet, ssh or asdm to the standby firewall?
If it comes up with the username and password that means the connectivity is there.
If you have tried ssh, try telnet or asdm and see if that works.
-KS
