VPN client software for Vista 64-bit
Dec 9th, 2009
Is there a Windows Vista 64-bit version of the Cisco VPN client software?  I have Windows Vista (32-bit) users connect to a SR520 using Cisco VPN client, but the same VPN client software won't install on a 64-bit Vista desktop.
Thanks for your help in advance.
NYCiscoTech_2 Thu, 12/10/2009 - 07:54
For 64-bit OS Cisco recommends using the 'AnyConnect VPN Client' over SSL VPN.
Text from the Cisco VPN Client page:
The Cisco VPN Client supports:
Phillip Remaker Fri, 02/19/2010 - 16:33
Cisco VPN IPsec client beta (for version 5.0.7) for  Windows 7 and Windows Vista 64-bit is avaialble for CCO as of Feb 18,  2010..
Key Capabilities available for Beta Testing:
New   Platform support – Windows 7 & Windows Vista 64-bit  platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer  with a Cisco.com SMARTnet™ enabled login.
Please communicate  feedback (both positive and problems) to [email protected].
There  are no plans to support Windows XP 64-bit
