12-09-2009 11:28 PM
Hello!
Resently i try to add new virtual service in ACE4710, but while modifying policy map
i have got error message:
ace1/Admin# conf
Enter configuration commands, one per line. End with CNTL/Z.
ace1/Admin(config)# policy-map multi-match EXT_POLICY
ace1/Admin(config-pmap)# class AS_VIP125
Error: Unable to add object. Possibly exceeded max configurable object limit!
What is the limit ACE cry about?
How to overcome it ?
How to see "configurable objects" usage?
ACE4710 s Version A3(2.3) [build 3.0(0)A3(2.3)
Thanks.
12-14-2009 07:33 AM
CSCtb16968: Unable to add object. Possibly exceeded max configurable object ..
Will be fixed in A3(2.5)
But to be safe, you should open a service request and have the TAC verify your config.
Gilles.
10-08-2012 07:31 AM
Have you ever solved this issue?
I got the same error today on ACE30, A4(1.0). My config is quite long so this might not be a bug, but the real device limit.
L.
